fikse fm10
You can look up your tire on tirerack.com under specs for your specific tire and it will give you all technical info including tire rim width range for a specific tire.
Here is a link to the spec info for Michelin Pilot Sports on their site:
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
For the tire size you specified they show 9" as the minimum width and 11" as the maximum width so you should be ok but this does differ a little with different tires and manufacturers so look up your specific tire on their site and check to be sure.
