nice work. did you put a an fitting in the top of the AOS?
Cut the top off, drilled a 9/16 hole, and tapped with 3/8 npt and -10 AN fitting. Hose will route to a Saikou Michi catch can.
I had the line to the FPR turned down on a lathe to 8mm and installed a compression fitting to a -6AN end so I can plumb the fuel line. I hate the screw clamp ends with the covers.
It's getting a Vitesse Stage 2 with 55# injectors and a hotter cam.
I'm assuming this will come with all the other supporting mods (exhaust, wastegate etc.); if so this sounds about like my dream car, so I hope there is a dyno test once its back in the car...
