Some of my install pics...various items
Rather then posting all the pics here, I'll just post a link to a webshots album for those that are broadband handicapped...plus I'm too lazy to link them all.
http://rides.webshots.com/album/5598...Gs?vhost=rides
Much of this stuff is frequently asked about so these pics show how I installed the following for reference:
Cobra carbon fiber seats with slightly modified stock brackets.
Modified turbo coolant hoses.
AVC-R solenoid and display unit.
Pillar dual gauge pod.
AFM Link MAP sensor and controller.
Ashtray delete plate.
Painted calipers.
Rear 951 badge and 968 wing.
Lindsey turbo oil filter.
AOS breather which shows no oil gathering in the filter, no need for a catch can.
Injector resistors.
T fitting into KLR line.
Painted calipers.
Injector resistors.
Originally Posted by tyro
Time for a tire upgrade!
Originally Posted by ausgeflippt951
Did you have to do much modification to the gauge pod?
Originally Posted by Duke
Nice stuff. Love the seats!
The stock passenger side bracket fit quite well. The front hole lined up perfect with the new seats. Since the width was the same I just had to drill a couple new holes in the bracket for the back to bolt in.
The driver seat took a bit more work since the original was powered. This required cutting off the powered adjustment items that the factory welded on.
The seats were ordered along with universal brackets but it turned out to be easier to modify the stock ones. The universal brackets would have required drilling new holes in the floorboard.
I've seen many posts about seat fitments and brackets so hopefully this will help someone.
