Photo request - radiator area
Hi folks,
I'm looking into grafting on the 951 hood latch carrier panel in my 931 and mounting my intercooler in the nose. Since one of my radiator fans just died, I wanted to check into bolting up the 951 radiator and fans too.
Are there any photos from inside the engine bay pointing at the radiator - installed and removed? I want to see how/where it bolts up. I'm sure there is one on here but I didn't come up with anything using the search.
Cheers!
nick
Cheers!
nick
Wow thanks! Those are great shots although it looks quite a bit more different than I expected in there. If you could add a shot from the top down you'll be my hero
Thanks!
Thanks!
Those pics are perfect. Looks like I'm going to have to find a 951 shell to cut into...
One final question, the fan shroud bolts directly onto the radiator? Or the side supports?
Hey folks,
I've found a local junkyard '86na - do the later na cars also provisions to mount the intercooler in the nose? It looked like the brackets were there under the nose but tough to tell.
Cheers
nick
Cheers
nick
