Cleaning pistons while they are in the car
have the piston you are cleaning at TDC, if paranoid about getting the crap all over the place, put a rag around the cylinder in the water jacket. Crap shouldn't be flying all over the place if you scrape it off. heck, a razor blade works decently too, just dont wanna go too wild with it and shave away at the piston haha...
Take your time and you should be okay. if you rush things, well... stuff goes everywhere.
Yes - clean them if you can. Brass or copper brushes work pretty well...along with a good dose of carb cleaner. Don't use a steel brush! I also like to spray carb cleaner around the edges of the pistons to dislodge any carbon deposits in/around the rings.
Rennlist Lifetime Member
The thing to be concerned about here is getting stuff in between the pistons and the cylinder walls, which is almost impossible to avoid if you just go at it without prepping. The alusil doesn't like contaminants at all. Chris White told me his method - use a bead of assembly lube or some other viscous oil based lubricant and apply it around the circumference of the piston - of course at TDC. Clean the piston top and the crap that would have wound up between piston and wall is now caught in the assembly lube, ready to be shop-vac'd out. I wouldn't do it if you aren't going to ensure that nothing can get between your pistons and walls where you won't be able to clean it out. Water jacket isn't a big deal, stuff some paper towels down there to catch most of the stuff and you'll be fine.
Originally Posted by M758
Did you confirm a bad headgasket?
Good information guys, thanks. Any other suggestions/hints/tips are certainly welcome!
no this is what you do. TAPE EVERYTHING and just have that one piston exposed @ TDC with a shop vac running have a brass or cooper wire brush with a 90deg angle drill and with some carb cleaner or something like it and drill away. BTW their is a very detailed thread on this step by step with pics if i am not mistaken. do a search not to be a jerk but its out there i know it. their is also somthing there that has to do with using vasaline on the outer rim of the piston so the dirt/grim doesnt get stuck inbetween the cyc wall and piston i have done my method before and worked very well but the write up on here on rennlist is allot better.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
