Tips on holding a flat boost curve - w/ single port??
#46
Basic Sponsor
Originally Posted by nize
hahah nice. no wonder you can hold flat boost. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
do you have a copy of the pc tuning software for dta? the website link says;
Not Found
The requested URL /software.htm was not found on this server.
Not Found
#48
Basic Sponsor
can you email it to me? i'd like to check it out.
#50
Drive-by provocation guy
single port with mbc can't hold flat boost. read this thread to find out why;
https://rennlist.com/forums/showthre...ighlight=boost
#51
toddk911;
1) do you know what your spring pressure is?
2) what psi is boost set at?
3) what turbo?
4) how are you monitoring boost?
5) do you have video in 4th gear boost to redline?
3) what turbo?
#53
toddk911;
3) what turbo?
3) what turbo?
.8bar Tial (also held flat with GURU modified stock WG)
18psi
LR Super 75
Autometer boost guage
Nope. No video.
The only times I have heard or read about rolling off boost curves is due to leaks, stock or worn WG or turbo running out of steam. An EBC can help some of these issues and aid in spool up, but is not needed for a flat curve.
I assume when you say flat boost curve you mean once X amount of full boost is reached, that boost level is held to redline?
