easy question(search did not answer)
Old 07-09-2007, 01:24 PM
  #31
special tool
special tool's Avatar
Originally Posted by JE_951
There is a guy on here edman951 (http://www.geocities.com/edman951/home.html) that is runing a gt35r and is hitting 1 bar boost at (I think) 3100rpm. I would think that a gt30r would give you 1 bar at maybe 2700rpm. Guessing it would be good for about 400hp?
IF you want good spool with great efficiency then contact pauertuning. Nize did a pauetuning write-up on his turbo and loved it.
Edman uses a GT30R.
Old 07-09-2007, 06:43 PM
  #32
Outkasted
Outkasted's Avatar
ok well i found out today that the only twin scroll housing come on t04 turbos. According to who i talked to that would actually increase my lag even if i did suceed in making it a true twin scroll. So i guess i will now look into the gt28rs unless anyone has some conflicting actual information. The source i got my info from is considered very reliable. The one think that comes to mind on the gt28rs is the block plate to make it an external wastegate how hard is that to get done.
Old 07-09-2007, 07:59 PM
  #33
gt37vgt
gt37vgt's Avatar
just reprace the WG actuator with a threaded rod.
or yes a smal block on the dump pipe assembly .
There is realy nothing rong with integral wast gates any how .I have seen no real evidence of external ones being much better .
I think they may just take the heat better but are hype really .
there are plenty of tuners here in aus that hardly bother with them and that does inlude 460whp 968's
you may be able to get the gt28 into a kkk 951 turbine housing .
hey i've got an old garret twinscroll exhuast housing at home .
think its t3 /t4 type can measure it up later if you like
Old 07-09-2007, 11:47 PM
  #34
JE_951
JE_951's Avatar
I believe that pauertuning uses garret bb turbo's and does integrate a 10# or whatever KKK housing you would like. But I am not possitive. If that is in fact what he does then it would be alot cheaper then buying a garret BB turbo and then having to do a downpipe mod and other lubrication/cooling line mods...
Old 07-10-2007, 12:13 AM
  #35
Ian Carr
That Guy
Ian Carr's Avatar
^ not if you know how to weld really good.
Old 07-10-2007, 04:40 AM
  #36
JE_951
JE_951's Avatar
true, but im guessing he cant weld...
Old 07-10-2007, 04:51 AM
  #37
Outkasted
Outkasted's Avatar
No i sure cannot weld. The price of the downpipe work would have to justify the turbo i guess.
Old 07-10-2007, 04:57 AM
  #38
gt37vgt
gt37vgt's Avatar
just buy 3" dump pipe for a jap high mount set up and maybe give it a little lobster back mod to make it fit right . if he preps it good someone on rennlist will weld it cheap .welding is just like painting its all in the prep work
Quick Reply: easy question(search did not answer)
