Blow-by
Old 07-05-2007, 01:49 AM
reno928s
reno928s's Avatar
Default Blow-by
Last Sunday I was at the Seven lakes drive and was told that blue smoke was coming out the tail pipe on acceleration and at 14 psi of boost. My mechanic installed a catch can, which I was told would eliminate the smoke if it was blow-by. But smoke still comes out the tailpipe and the catch can has minimal amount of oil, maybe a teaspoon. Do you thik it's blow-by even though I have the catch can? TIA, Reno
Old 07-05-2007, 06:20 AM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
Sounds like the turbo is going south.
Does it ONLY smoke on boost? off boost everything is fine?
Old 07-05-2007, 07:46 AM
special tool
special tool's Avatar
What sort of catch-can is this?
I feel like a broken record but you must keep the vacuum circuit - we have free vacuum available because of our turbos, and some knuckleheads elliminate it!!
That kills me!
A whole industry of guys making vacuum pumps just to put negative pressure into theWET sump, and 951 guys rip it out
Anyway - what happens is, you can overload the turbocharger exhaust seals from a drain that is or can be somewhat obstructed.
Porsche wanted vacuum there - probably a good idea to keep this one.
Old 07-05-2007, 07:51 AM
Ski
Ski's Avatar
morn'n tool.
Jim, do you drill the opening of the AOS to make it larger, get the fins out of the top? Just curious.
Old 07-05-2007, 08:03 AM
special tool
Mornin' Ski
I have done both.
Drilling it I picked up condensation only everytime I started the car from cold.
Right now, my AOS is not drilled, and I pick up nothing, not even water - so I might open it a little.
Old 07-05-2007, 10:22 AM
reno808
reno808's Avatar
Reno928 if i go to your this sat for the tires i'll take a look how your mechanic hooked up the catch can. I have one on mine i just installed a couple of weeks ago. i have mine hooked to the AOS and to the J-boot. How is your hooked up?
Old 07-05-2007, 11:52 AM
reno928s
reno928s's Avatar
hosrom_951, Yes it only smokes under boost. It never smokes on start up or regular driving. Under hard driving I'll go through a quart every 350 to 400 miles.
special tool, it's the Lindsey catch can and my X mechanic installed it. ST can you explain in baby talk what the heck your saying with negative vacuum. That way I can look to see if my mechanic installed it correct. Thanks
Old 07-05-2007, 12:48 PM
special tool
Well - I don't want to say bad things about 951 vendors, but I disagree with them on this.
The 951 likes to have the catch-can routed to the turbo intake - simple as that.
I have had many different can configurations and 6 different turbos on my car, and that's the way it is.
I have seen TWO cars with oil smoke (after boost at idle) now stop doing this after the vacuum was enabled again (the way the factory did it)
Maybe Rolex will offer some experience here.
Old 07-05-2007, 01:08 PM
LFA951
LFA951's Avatar
What if you have a MAF, then you can't reroute it...
Old 07-05-2007, 01:14 PM
TRP951
TRP951's Avatar
Mornin' Ski
I have done both.
I dont pick up anything either right now so would you recomend opening it up?
Old 07-05-2007, 02:36 PM
special tool
huh???
Sure you can - I did.
Old 07-05-2007, 03:09 PM
reno808
reno808's Avatar
Its even easier to install it on a MAF setup than a the stock j-boot.
Old 07-05-2007, 03:58 PM
LFA951
LFA951's Avatar
Well, the LR pipe only has a port for the BOV and the Fuel vapor hose!!
Old 07-05-2007, 04:03 PM
special tool
yes - that is only the start of the trouble.
I think you should talk to Rolex.
Old 07-05-2007, 04:04 PM
reno808
reno808's Avatar
Thats the problem because LR designed their pipe to use there catch can and their catch can does not hook up to the j-pipe. Like a vitesse j-pipe you will find that port so you can hook up the aos hose/catch can hose
Quick Reply: Blow-by
