Maxlife oil does work!!
#31
Hey Man
Originally Posted by shaheed
btw there have been posts on rennlist, by people who work in the oil industry, about how much the quality of mobil 1 (which is the oil that lots of folks like to recommend) has definitely decreased over the last few years. research and draw your own conclusions.
We all deal with this issue in our own way and I feel it's always best to do your own homework rather than listen only to idiots like me.
![nono](https://rennlist.com/forums/graemlins/nono.gif)
#32
Funny how Australia Max has more ZDDP than what is sold in the US.
http://www.valvoline.com/products/Maxlife.pdf
http://www.valvoline.com/products/VR...otor%20Oil.pdf
Low levels of ZDDP, (anti-scuffing agent) are causing failures and premature wear in all sorts of engines. It's been reduced because it's hard on CATs, emissions, and manufactures like/want us to buy their expensive replacement parts. With all of the scored piston walls you read about on this board alone, (detonation issues aside) adequate ZDDP is a must. Many people here preach/run synthetic, but these oils weren't around when our cars were developed. I'm in the camp that pre 993 engines are better off using Dino because they weren't developed around synthetics. Adequate ZDDP was however in most oils back in that day and that was a good thing.
#36
Originally Posted by LFA951
It's called MAX life cause it's the best!!!
There is actually a reason that they chose that name. Perhaps you should figure it out.
The additives used in the oil are there to help stop leaks the wrong way. Eventually they will build sludge, just like all of those sanke oil sealants.
I noticed that you said that you tightened your oil pan bolts, then changed the oil and now it leaks less. Now think with me (I know that's tough for you) could it possibly be that the proper tightening of the oil pan is creating a better seal, or is it your "magic" oil.
Of course you are the guy who first came here telling anyone who would listen that AMSOIL was the ONLY oil worth a crap. lol
#37
Paraffin based dino oils has better additive binding qualities than synthetic oil . This would help hold the viscosity up in critical areas.
Btw: I just talked to a friend of mine whom is very knownledgable when it comes to oil , additives, chemical and molecular structures .
He said that last track day he saw a oil temp of 150deg C (302deg F ) in his 951 but still had 4Bar of oil pressure down the straights . Knowing his oil would have no problem operating at this temperature and showing that it would be viscosity stable at these temps.
This is a 400whp/550nm car with only stock oil cooler.
#38
TRB0 GUY
Hahaha... disregard any and all previous statements about MaxLife from this thread.
I just realized that I am completely full of ****. It's not MaxLife I use... it's Valvoline DuraBlend (which is a synth/dino mix). Hahahaha. Whoops.
#39
Originally Posted by ehall
That's simply retarded.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
#40
Originally Posted by sweanders
It also lists that you can run the car on low octane fuel, but the preferred is 98 RON.
#41
Originally Posted by 333pg333
Anders, at what stage in our original owners manuals did it say to use only synthetic oils? Never, as they didn't have them then. Firstly there is no such thing as a totally synthetic oil at our level of engines, and secondly oil is in our engines to do more than be slippery a.k.a. lubricate. It is there to act as a suspension or shock absorbing property between all the fast moving expensive bits of metal that are trying their hardest to smash each other into oblivion. The lower visc. the grade of oil the more likely it is to heat up and get too thin and allow just that to happen. Look at all the people who have had their motors blow up on this and other forums and do a poll of how many of them were running things like M1 'synth' low visc oils. Most won't admit it even to themselves as it's easy to be caught up in the advertising propaganda of billion dollar campaigns, but our cars don't like low visc. 'synth' oils. Porsche themselves used straight 50w oil in their race cars for years, and from another brand than the one that emblazoned their cars.
#42
Hey Man
Actually, that statement is incorrect, Amsoil was the first synthetic oil ever made back in March of 1972, over a decade before the 951 was first introduced, so synthetics were out there, just not readily available or as popular as they are today... ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
The first 'commercial' synthetic oil was introduced by All-Proof in 1970, the French Company Motul in 1971, Amsoil in 72, followed by Mobil 1 in 74. No matter when it was made no one is arguing that Amsoil isn't a great product. Personally I feel Amsoil is nothing more than a great product but unfortunately sold under the despicable practice called network marketing. I do not want to join a 'club' od dealers just to buy it for less than $7.
From all of the heated opinions and angst concerning oil preferences here you would think people were roasting babies or something.
#43
#44
Originally Posted by KuHL 951
Actually you are incorrect also.
#45
