SKF Pilot Bearing #
The SKF pilot bearing box (we're talking clutch pilot bearing, that the TT end goes into, correct?) I got from either Lindsey or Paragon has 6202-2RSJ on it. The # on the bar code is 0 85311 06258 9 (made in Argentina ! ). Don't want to dis-agree with Hussam, just passing along what I got and am using.
UAE Rennlist Ambassador
mtnman82: I understand that there is one pilot bearing, which sits between the crankshaft and the flywheel. I was already searching for some SKF part numbers for the front wheel bearings and, by chance, saw this thread. I just cross referenced the Porsche part number 931 102 111 00 and i found that SKF number.
Since you have it physically, obviously you would be right on the number, and i did mention i hope i am right
