how do you pull the bat cables through the firewall
Old 06-18-2007, 12:14 PM
mortymower
mortymower's Avatar
Default how do you pull the bat cables through the firewall
ok so they are unhooked from the bat and the little wires are unhooked from the main pos wire, but how do i push them through the firewall with that gromet there. I tried to pry it out and almost punctured it. do i have to unhook the cables from the bat post connectors????
Old 06-18-2007, 12:20 PM
951Tom
951Tom's Avatar
I was replacing my cables so I just cut the wires near the grommet and pulled them out, otherwise you'll need to disconnect them at the starter and pull/fish them up and out thru the grommet. A little lube on the grommet made fishing the new wires thru easy.
Old 06-18-2007, 01:05 PM
mortymower
mortymower's Avatar
what about the negative, how many places does it connect to i unhooked the one on the wall in the bat box and i see the other one going toward the belhousing but does it split anymore
Old 06-18-2007, 01:22 PM
Cory9584
Cory9584's Avatar
you can pull the whole grommet out with the cables still attached if thats what your asking. otherwise you need to disnonnect the ground from the bell housing and the hot from the starter.
Old 06-18-2007, 01:44 PM
PorscheDoc
PorscheDoc's Avatar
You can pop the grommet out, or else Silicone is your friend.
Quick Reply: how do you pull the bat cables through the firewall
