Running Rich + backfire (pics)
At idle or regular driving, the car A/F meter remains at stoich. When i'm at WOT or approaching it, the A/F goes rich. The problem gets worse when I go from 14 to 15 psi boost. Also when i'm changing gears, I will get the occasional backfire. Any ideas what it could be? I'm leaning toward the oxygen sensor or injectors.
Car has no cat, no oil in intercooler pipes, and no vacuum leaks.
picture of crusing and idle:
![](http://img.photobucket.com/albums/v324/ilikeballistic/944/runningrich1.jpg)
picture of WOT
picture of WOT
![](http://img.photobucket.com/albums/v324/ilikeballistic/944/runningrich2.jpg)
Originally Posted by MPD47
Horrible Narrowband A/F gauge with generic readings. Get a Wideband with numbers and then post how rich you're really running.
Originally Posted by Ballistic
What would you recommend?
My car runs rich under WOT too, its normal and a good thing
Hey Man
There is no magic pill. I think if my cars run rich under WOT I count it as a blessing opposed to running lean. Every run I have been on the 951's always have a bit of unburnt fuel in the exhaust. I would much rather foul an O2 sensor or cat than buy a new motor.
Basic Sponsor
Dude that's horrible, adjust your a/f to run 14.7 at wot, lol , your car is running fine just if you want something simple and accurate get the AEM wideband for $ 218.00 installs in 20 minutes or so.
check the video it appears next to my boost gauge. I also use the lm-1 for datalogging.
http://www.youtube.com/watch?v=4tAdsNsXOGk
edit: nevermind you are using lm-1
edit again:
Lart, why would you buy the AEM for 218.00 and then the lm-1 for 350.00 when the Zeitronix allows you to do all that for less?
Basic Sponsor
AEM wideband won't let me datalog and make adjustments correct?
edit again:
edit again:
Originally Posted by The DareDevil
Speaking of Zeitronix... I should be receiving a package in the next couple days ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I also found this:
http://members.rennlist.com/tom86951...nd%20wires.htm
hopefully you can use it on your 944
