^%$#! distributor cap - tricks to getting the lower bolt off?
Basic Sponsor
I can get it out in less than 10 seconds, but you need a special tool
LMAO lart. Yeah I got it using clarks method of finger painting and rotation, worked flawlessly. I used a stubby #2 phillips on top, and a stubby #2 on the bottom but used the other trick here of using a short crowbar to wedge the screwdriver in and turned it. Great suggestion whoever that was. Cheers.
Originally Posted by hosrom_951
It is easy if you know how....
Disconnect the coil to distributor wire.
Remove the top timing belt cover (the black top cover).
Remove the distributor cover (where it sits on).
The cap and cover come out as one piece, put it on a work bench and just remove the cap. I find this method handy, since when you install the cap back onto the housing, you can see exactly where the cap screws catch onto the right points....
Shouldn't take more than 10 minutes to remove it.
