Coolant system pressure -- please explain
There seem to be a lot of overheating problems being posted recently. I understand how the cooling system works in terms of heat and coolant flow. My question is what role pressure plays in the cooling system?
Why is pressure necessary, and what are the potential resulting problems if this pressure is not maintained?
Originally Posted by Jeremy Himsel
Each psi of pressure in the system raises the boiling point of fluid. A bad cap will result in lower boiling points.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Thanks Jeremy.
The first sign of my stock head gasket going was that it started burping coolant when the engine was ran hard. The head gasket went at 90K and was deteriorated NOT blown out by too much boost.
Originally Posted by shiners780
It's as simple as that???
Well now don't I feel silly...I guess I should have taken something other than just business courses in school...
Thanks Jeremy.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Thanks Jeremy.
Not exactly but sort of. A 15 psi cap will raise the boiling point by 40 to 50 degrees. The amount of coolant/water factors in this as well.
A Stant pressure tester was the best 40 bucks I've ever spent for this car.
