Electrical Advice Needed
I am having problems w/ my turn signals.
All bulbs light up at one time or another just not when supposed to.
If I turn headlights on all lights are on except R rear amber(turn signal)
If Headlights off sig
Right turn signal activated both amber bulbs F & R blink fast and red side lights F & R on but dont blink
Left turn signal works fine all 4 F & R amber and side lights blink normal
If headlights on
Right turn signal activated front and rear blink fast like above , now side lights work but dont blink, stay on
Left turn signal all 4 lights stay on and dont blink at all.
Sugesstions???????????
thanks in adv
If headlights on
thanks in adv
Sounds like a bad ground or water has made it's way into a harness/terminal. Do a visual inpection of all underhood and hatch area grounds. Also, pull the seats & carpet and inspect all wiring runs and connections for corrosion. A bad ground will cause the lighting circuit to "pull" earth or (-) battery from wherever it can thus creating closed circuits when the physical switch is open. PITA but very common with a 20 year old car.
