Excitement short lived.....
UAE Rennlist Ambassador
Car is put together after a new radiator, cooling system flush, headers welded, new throttle body/tps and new injector seals.
The car ran great at no/low boost, around town and so on.
The clock hit's midnight, the streets are empty, i'm sure this site is very tempting, as my foot just found itself dead flat and hard as a brick on the pedal...
![](http://forums.rennlist.com/upload/image006_copy4.jpg)
Suddenly, i smell a strog stench of petrol, really strong, everything else looked fine......
Went on the right shoulder, hazered lights on and brough the fire extinguisher with me as a precaution. By the time i got the hood open, there is a huge fire.......
I managed to put it out, called a towing service, got to me in 20 mins or so....
Now im home, the engine bay is covered in white power......and from what i see, injector 1 popped off the fuel rail, the clip is there and one of the fuel rail bolts on the intake is missing. I recall testing the fuel system with the engine off when i replaced the seals, and torquing down all 4 bolts to spec.......
Injector 1 is still leaking fuel as we speak, the connector on the injector harness is fried at that injector only.
Suprisingly, everything else is untouched at all............nada. I have an injector harness from my 88 NA, so that's not a big deal, how ever i require one new injector and have the system checked out to find out why it popped off.
Injector 1, wet even after the power:
![](http://forums.rennlist.com/upload/image008_copy2.jpg)
Engine bay:
![](http://forums.rennlist.com/upload/image009_copy3.jpg)
Thing is, there is Cyclone Gonu coming off the Arabia Sea headed this way, it is a category five storm and it already made it's way to Oman with wind speeds of 260kpr/161mph, it hits Dubai in the morning with wind speeds of 100kpr/62mph or so......
![](http://forums.rennlist.com/upload/06_nt_gonu_5.jpg)
Sorry about the pics, they were taken with my phone.....
Engine bay:
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
J/K
Seriously... having ridden out numerous fairly big storms myself, keep safe. -Sorry about your fire issues, but at least you got to it quickly. -Good work!!!
Hope it all goes well from here on in... -keep safe!
Keith
Keith,
I was airborn, that stock K26/6 sure does pack a punch when on boost, enough to get the 951 in orbit![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
I just hope that the damage is restricted to the injector and injector harness......and thanks.
All I can say is, thank goodness you had that fire extinguisher.
I hope the damage is just superficial. On the early 951 cars I believe there was a factory recall for fuel lines that were prone to causing engine fire. I assume your car had this update done at some point?
Matt, will do, the intake is coming off tomorrow.........
auch, good think you caught it so early, for the future you want to replace that powder extinguisher with foam or some gas one. that powder is messy and makes stuff rust.
I'm having 1 automatic system where I pull the lever and it sprays foam over fualrail and that area, and also one in rear near tank. in addition I have a "loose" foam unit to help others or odd place fires. it's aluminium and adds very little weight.
hope you get it fixed soon.
Originally Posted by special tool
Hosrom - sorry to hear about the fire.
I am proud of you for bringing that extinguisher and bitch-slapping that fire.....
Plus 2 points for you.![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Originally Posted by Bill
Sorry this happend to you. I use locktite blue on every nut/bolt that I remove and reinstall.....especially the fuel rail bolts!
HALATRON or (HALON if you can find it) is your friend.
It might cost more up front but if ya gotta use it the clean up is MUCH easier than this. Ok I am super glad you had an extingisher with ya. That saved the car, REALLY it did. These things can go up QUICK ! ! ! Sorry about what got burned,
IPSC
IPSC
Good idea to clean up the powder with water?
Just asking.......
Just asking.......
Just saying.........
Originally Posted by ittia
Just leave it outside with the hood up and maybe the cyclone will clean it up.
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Damn dude!
Hos, glad you and the car came out okay. We've all seen the pics of the guys whose car went up in smoke. Let us know what you do to clean it up and what the damage is.
BTW, if the storm gets to Dubai @ 60 knots wind speed, it will gust higher. Either way, this one won't be too bad. We Floridians ride out three of more of these a year.
Now 160? THAT would be F-ing scary crap!
Good luck bud.
I bring two things with me when I take my car out, fire extinguisher and marshmellows. If the extinguisher can't put the fire out , no need for it to go to waste. Reno
