ARP head studs - experiences?
Old 06-19-2007, 07:31 PM
  #46
special tool
special tool's Avatar
I would like to point out that the mls on my car has been torqued/installed 3 times.
It is 100% fine and I plan on keeping for the dyno and drag races coming up.
Old 06-19-2007, 09:27 PM
  #47
tyro
tyro's Avatar
I'll assume you're joking..you've mentioned several times that the wide fire ring gasket is the way to go..
Old 06-19-2007, 09:37 PM
  #48
KuHL 951
Hey Man
KuHL 951's Avatar
Originally Posted by Cory9584
...also where does ebs get their studs from? another similar application? arp told me theres no such thing.
I talked to ARP Special Products Division today just to find out a few things. He said they build the 'specials' for engine builders such as EBS and others and they are not in the catalog. We talked about a few people here having leakage issues with the 65# final pull. I got the feeling that it wasn't ARP's value and more representative of the particular builder. He went through the specs on the hi-strength alloy with me. For the 12mm stud 'as designed' he said a safe pull was 85-86 ft-lbs. He said at 95ft-lb the stud will start to stretch and can yield detrimentally at 100+. To me it verifies that picking 80 ft-lb for mine will be fine, especially after headwork. I just thought I would toss that in there. It may very well be that 65 ft-lb just isn't enough unless the block and head have both been milled correctly for a rebuild. I can imagine that the independent builders do the machining as standard procedure for anything they are having to guaranty themselves.
Old 06-19-2007, 09:56 PM
  #49
billindenver
billindenver's Avatar
65 was not enough for mine with the head and block freshly milled. At least not with a stock type HG.
Old 06-19-2007, 10:19 PM
  #50
special tool
That was a while ago.
I have good luck with the newer mls with the fancy glue coating on them.
Old 06-20-2007, 10:41 AM
  #51
tyro
tyro's Avatar
65 wasn't enough for me either. What value did you go with, Bill?
Is your car up and running again - and not losing coolant?
Old 06-20-2007, 12:31 PM
  #52
billindenver
I went with 85. So far so good, but I have not checked retorque yet, nor has it been on the track.
Old 06-20-2007, 01:21 PM
  #53
KuHL 951
Hey Man
KuHL 951's Avatar
Did you end up using the initial settings that came from EBS and just up the last pull? Did you relax them 180 deg. after the first torquing. Glad to hear it's holding so far.
Old 06-20-2007, 01:53 PM
  #54
tyro
tyro's Avatar
With the ARP studs, one end is fine pitch versus the stock studs that have identical thread pitch on each end (12x1.5).
In thinking of bolt design, how are thread pitch and applied torque related?
Given a coarse thread stud such as the stock head studs, would a fine pitch stud of the same material require more or less applied torque to achieve the same clamping force assuming identical thread lubrication? How much is the difference? Minimal?
Since the studs are made for EBS by ARP, who came up with the torque value? ARP?
In short, is 65ft-lb of torque applied to the stock studs the same as 65 ft-lb of torque applied to the ARP studs?
Either way, I'm going with 85.
Old 06-20-2007, 01:59 PM
  #55
billindenver
I just increased the last pull, then let it sit overnight...and backed off 180 and retorqued. It then set several days while I waited for new exhaust studs to arrive and I retorqued again.
Old 06-20-2007, 02:47 PM
  #56
toddk911
Drive-by provocation guy
toddk911's Avatar
After having my HG done recently with now Cometic MLS and ARP, I have had no issues.
Also, the guy that did mine did not go by ft/lbs but by distance and/or number of threads exposed to know how much to tq. it down.
Old 06-20-2007, 06:03 PM
  #57
TRP951
TRP951's Avatar
the only thing about that is you have to make sure to install all them the same height or it will differ from stud to stud
Old 06-20-2007, 07:34 PM
  #58
KuHL 951
Hey Man
KuHL 951's Avatar
ARP has you set the studs with a fixed deck height anyway and wants the Loctite set before torquing. It sounds like counting threads would be a bit subjective but I see what he is going for but in a real complicated way. 80 to 85 ft-lb and be done with it; recheck if you have leakage or have the camtower off for some reason.
I'm more concerned about my machine shop getting the old studs out.
Old 06-20-2007, 11:22 PM
  #59
Tom M'Guinn
Tom M'Guinn's Avatar
Hmmm... sure he didn't use the "torque angle" method, in which the torque is set by measuring the amount the nut is turned? I can't imagine getting a proper/consistent torque by counting threads.
Old 06-20-2007, 11:24 PM
  #60
Tom M'Guinn
I suspect that to be the case; so do you have any idea why the engineers/assemblers at Porsche put so much Loctite in there to begin with?
Pure speculation, but wonder if it was to keep the studs from turning while a machine torqued the nuts.
Quick Reply: ARP head studs - experiences?
