Oil cooler replacement
My oil cooler has sprung a leak. Actually, looks like the threads on the bottom fitting have given up the ghost. So, I am going to replace it. Are there better options out there for oil cooling that do not park in front of the radiator? I know the stock cooler is not the best on the planet, but it has done me ok for a decade so I'm sure it wouldn't be a terrible choice. You know the deal though, if its being replaced...at least look around and see if there are better out there. I know I get pressure drop on the track....so might be time for an upgrade if there is room to put something bigger/better. Thoughts?
you can fit a setrab cooler easy, there has been some recents threads on this, a member also provided a neat duct/drawing for a 13? row one I belive it was, I will use his drawing and just make it longer on the sides to fit my 19 row.
