z06 pistons
I noticed the other day that Corvette z06 (LS7) pistons are 104.8mm in diameter, other details in the link below:
http://www.drivingenthusiast.net/sec...006/08/22.html
The pistons have polymer coatings on the skirts but are made to run in a pressed-in liner. The rings are also likely incompatible with Alusil bores, however they might be perfect in a sleeved block. Piston pin is probably set quite high. It'd be great if the rods could also be adapted as they are Ti but what are the odds?
-Joel.
-Joel.
