How much is a S2 Trans with oil cooler and LSD worth?
The PO put one on my car and I would like to get a 968 box in there so I might want to sell. How much is it worth?
Freedom Enthusiast
Oil coolers and LSD's are nothing but trouble and a tranny is a pain to ship so I doubt anyone would want it. I'll bite the bullet and pay for shipping to my house so you don't have to deal with any more hassle.
Seriously, I agree 2K is the number.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Since S2 transmissions did not come with oil coolers, this one has been built up using either a turbo trans with an S2 R/P, or possibly adding the LSD and oil cooler from a turbo trans donor to an S2 trans.
You really would need receipts for the work, showing what was done, and more importantly, who did it. If its not done right, by a knowledgible shop, it would be a big risk for someone to buy. If you have solid receipts from a known shop, and its fresh, its worth more than $2k. If joe-bob did the build/swap in his garage, then probably under $1500.
S2 transmissions came with the oil cooler as stock equipment on cars for the Swiss market.
(BTW, Swiss cars had specific features such as the plastic casing "wrapped around" the gearbox and an extra small air box before the AFM, both fitted presumably to satisfy the tough Swiss environmental legislation).
Oddjob,
He states it was ordered from the factory on the Purchase Order so it will be a factory transaxle not a cobbled together job by Joe-Bob. As I recall the turbo gearing is slightly different to the S2 maybe somebody else can confirm this?
One thing to be aware of is that I have had transaxles with oil coolers that have not been LSD so just check it out before selling. To test, lift the rear end of the car off the ground and turn one wheel forwards, if the other wheel turns forward you have a LSD. If it does not you have an open diff and the value is comprehensively less.
Cheers
Tom
Why do you want to go to the 6 speed out of curiosity?
IPSC
I just have always liked the 6 speed, I like the smoother shifting as well. I would not spend alot more for it but if I can sell this one for 2K I only have to add a bit more to buy a 968 box so I was considering it. I have not looked at the option code yet but when i get back from florida I will check that out
Originally Posted by tommo951
Oddjob,
Cheers
Tom
Cheers
Tom
PO = Previous Owner, not Purchase Order. I dont think his car (Im assuming its a 951) was ordered from the factory with an S2 gearbox. And I doubt the gearbox was imported from Switzerland...
Turbos have 3.375 Ring/Pinion. S2s have 3.875 R/P. 1-4th gear sets are the same, but the S2 has a taller 5th (0.778 vs 0.829).
