oil leak? dip stick seal?
I cleaned the area(s) where I thought it was leaking, to two big areas are at the oil cooler, I assume I can get seals for this? it looks like its leaking at the connections, and either at the dip stick tube, where it goes into the block, OR just above the area, I hope its not just above if so it might me the OAS? leaking down, any ideas, where to buy the seals, and how much? thanks Jeff
