Who can do custom tuning?
May need a custom chip made for a car. Car has a bit of a frankenstein setup, T04E, autothority MAF, 3 bar fpr, stock injectors.
I'm open to all options, but obviously would prefer to not rip all this stuff out. Car is running very rich right now.
Currently has an Autothority chip I believe. Car had a K27 setup from Powerhaus that came with the turbo, MAF, etc. Unless Powerhaus does custom chips?
Yeah, but does John have a chip for the T04E? Or at least something close enough that I can then tweak it to where it needs to be with the SMT6?
I'm up at altitude too, even on my old 951s with John's MAF, I needed an SMT6 to tune it. Cars run alot differently here than at sea level...
Also, anyone have a T04e on their car? If so, when do you see 15psi? Not seeing it till 4000 rpm currently. Car has an mbc, shimmed rebuilt stock wastegate, bursch test pipe and 2.5" borla cat back...
