10 speaker Question
10 speaker Question
I have a 86 951 and want to install 10 speaker door panels,
My thoughts please advise,
I have a eclipse head unit to run not sure of power,
I was going to install a 3 way compents system in the door, not looking to spend alot maybe 300$, can I fit 6.5" woofer 4" mid and tweeter.
I have memphis 4x6 in rear, and plan to put a KLA w/ 8 and amp in the corner, would I need to run an amp due to the 3 componets in the door. I currently run a similar set up in a truck w/ the unit and it is fine, except I have a 2 way component in the door.
Is the stock wiring fine, If it is stock what color would it be, this car has had a few owners.
Steve
Steve
I just installed a 3way setup in the front of my car (ran new wires because its rather easy to do and you might as well) and they are definitely underpowered with the hu I'm running. Think its rated at a max of 35watts per channel. The two way component set in back seems to work fine with that power, but the 3 way components in front are underpowered.
Did a set of MB quarts that were on sale, I think they ended up being around $300 for the fronts. Got some QUA 210s and then added in some RVX 216s, or something like that.
