WTB: '86 hubs and control arms
TRB0 GUY
I'm hoping to swap my '87 hubs and uprights over to the non-ABS '86 units and am hoping to snag all the required pieces from a rennlister on here with an '86 parts car.
Does anyone have everything I'd need? Thanks in advance.
-Kevin
-Kevin
TRB0 GUY
I have been offered everything I need for the front: spindles, hubs, rotors, and a-arms. Does anyone know how much this would all be worth with half-life rotors, and a-arms with over a hundred track days on them??
Also... does anyone have the rear components? Lart, don't you have a gagillion parts cars?
yea, why do you want to back-date? Also, you don't want half life rotors. Buy new ones. You can get the front pair of zimmermans on ebay for $200 shipped. As for the control arms with 100 track days, the ball joints probably will need replacement in the near future
TRB0 GUY
Originally Posted by Bonestock951S
Not trying to discourage anything, but wouldn't putting 86 parts on your car revert you to the earlier offset and give you a harder time with wheel options?
-Darwin
-Darwin
The arms are known to be "well-used" but still good for street use, at least. I plan on fabricating my own pair after these are worn out anyways. The rotors are also still good, but used. I'm not going to drop $200 on new rotors yet if I don't have to (which I don't).
TRB0 GUY
No, the condition of my parts is irrelevant, really. I'm hoping to change over to non-ABS, and simply wondered if any of y'all knew the value of these parts.
...and I'm still looking for the rear hardware if anyone is willing to offer it.
Hey Man
-Darwin
-Darwin
It always amazes me when people say this. Can the late guys run Fuchs, CC's, or Turbo PD's? No
Can the early guys run just about any later offset P-wheel with spacers or early BBS or Enkei w/o spacers? Yes
Now exactly who has the least wheel options?
+1
I did the same thing, back dated to 86 rear hubs and rotors. That gives you alot more options.
It was the only way I could put 18X10 wheels that had a 3 inch rear lip.
TRB0 GUY
Originally Posted by 70K951
+1
Just some ideas to pass along. I race a 86 951 w/ 16 x 8 early offset wheels. I run steel 83-85 control arms and ball joints. The arms can be box welded and replacing the ball joints only requires 3- 8mm bolts. The arms and ball joints can be purchased new for around $100. THe reason this is to my advantage is with a stiff, lowered ride the stock cast arms are known to fail and upgrading to aftermarket arms would require me to take a 2nd. mortgage.
TRB0 GUY
Thanks Matt, I appreciate it. I was actually planning on doing that in the long run if the dimensions were the same, but for right now, I actually realized I don't need the change in the front to fit the wheels. I can actually just disable the ABS system, and convert the rear over to get the desired outcome.
