hesitation,sputtering on left hand turns
well i had the new race car out on the track last week and really had a great time until i started getting some hesitating and sputtering in the left hand turns...so then i came in replaced the plugs and went back out and then the car shut down right before pitting ..so i black flagged the session and had to get towed in and put the car on the trailer(luckily it was at the end of the last day)....im thinking maybe a fuel problem but if anyone has any suggestions...i am listening.
thanks
Doug
thanks
Doug
Start easy. Pull the fuel pump relay. Use the 3 way jumper technique to bypass it...and see if the car starts. If so, replace the relay and try again (I had your same symptoms on the track once...if I jerked the car side to side it would take off again but then sputter in turns later...was faulty relay). Do you have a fuel pressure guage? Is there fuel in the rail after it dies? How about your oil pressure when it sputters?
Cap and rotor?
I would start by verifying fuel pressure and then move through the paces from there. Maybe take the fuel rail off, turn it upside down and see if it sprays during cranking. That would mean fuel is being released...so look at spark from there (make sure the fuel has evaporated before applying spark anywhere for the love of allah).
Good luck and let us know how it goes.
Cap and rotor?
