Interchangeability & WTB: pass side rear spring plate
Need pass rear spring plate - plate goes from torsion bar to trailing arm.
got mine apart and surprised to find screwed up stuff
Please let me know what you have - really wanted to get car together by the weekend
I know it would be more work! But You should check out the elephant racing bearing set up it's pritty sweet! Is the issue that the rubber is worn out on the spring plate? I don't know if the n/a is the same or not...But I would think that they are the same but not a 100%!
issue is that the spring plate is actually bent
could bend back, but car serves track duty and I am not real comfortable bending it back as it will be predisposed to bending at that point again
This car also had tough alignment on this side
can visualy see how bent it is. Pic may not show clearly but will try to show - is bent right after trailing arm attaching bolts
Waiting for details from a few people. Please let me know as soon as you can. I really need to get parts on the way to be back together this weekend. Thanks much everybody.
Thanks to all that replied with PMs
And a big thank to Lart! My favorite mexifornian Thanks buddy!!!
I recieved today and have heat treated (AKA as removing rubber bushings) and bead blasted. Will get etching primer tomorro wand hopefully in paint. Should give enought itme to cure befoe new bushing arive Tuesday
Thanks to all
Thanks to all
Basic Sponsor
Thanks to all
Thanks to all
No problemo my man.
