944 Turbo S/928S4 Brakes.... Questions
Old 05-15-2007, 09:53 AM
Skip Wolfe
Skip Wolfe's Avatar
I agree with the others that it is definitely a worthwhile upgrade. The biggets issue was that it has taken me a while to get used to the better stopping power, and I keep overbreaking/breaking too early - not a bad problem to have.
Originally Posted by Thom
...This allows for heel & toeing, as 951 S brakes begin to be effective when the brake pedal is basically at the same level as the throttle pedal (at least this is true when using stock pads). It is impossible to heel & toe with the 951 as the brake pedal travel is much shorter...
I found that there was minimal difference in heel toeing between the non-S and S4 calipers.
Originally Posted by 944Fest (aka Dan P)
I've been told by a Porsche parts counter guy the 993 and TS/928 calipers are not directly interchangeable, they are different part #s. IIRC, It was something about the position of the crossover tube that needed to be swapped over. Easy enough to do, I suppose. Does anyone have first hand experience?
I have a set of 993 calipers and they worked fine with the S rotors and the caliper adapter.
Old 05-16-2007, 02:34 AM
Olli Snellman
Olli Snellman's Avatar
"Big" Reds/Blacks are same kind of old fashioned design like the original calipers are. I would go to bigger monoblocks.
Old 05-16-2007, 03:41 AM
333pg333
333pg333's Avatar
Haha, Olli's favourite subject. lol. The only thing is on a stock hp car the GT3's are really overkill for the amount of unsprung weight you increase by IMHO. If you want the added bling factor then go for it!
Old 05-16-2007, 03:49 AM
Olli Snellman
Quick Reply: 944 Turbo S/928S4 Brakes.... Questions
