Is is me, or could this work on a 951?
Might want to e-mail the seller and ask him the inlet and outlet hose sizes. I found a different one that looked like ours but with a different connector than either than ours or that one and it had a larger inlet hose nipple.
Please post back what you find.
Originally Posted by Chris Prack
They are basically the same pump. That one is for the heater core on a Mercedes. Change the connector and you are good to go.
I think I have that one in my 951. My father is a form MB tech and he has all kinds of spares. We replaced the turbo waterpump with a MB pum years ago. Not 100% sure it was this particular one, but being an 80 MB part it could be and it does look alot like mine.
Administrator - "Tyson"
Looks like the BMW pump we use to flow the water for the air / water IC's on supercharged 928's. Flows enough for that.
Can you tell more about that IC? I am planning to install water/air IC into my 951. Since a new turbo does not have water cooling i suppose i can use turbo water pump for IC.
