oil pickup question
oil pickup question
I removed the oil pickup tube/screen to have the LR baffle put in the pan and add the ring around the pickup screen. Is there any seal that needs to be replaced when bolting the pickup back to the girdle? Also what torque should be used when bolting the pick up tube back on?
Never got an answer and I am now under the car. It looks like one of the bolts that i removed to get the pickup out is a girdle nut. Is this correct? I'm not too sure what torque this gets bolted back on at. I have the shop manual but it doesn't refer to a girdle. I found crabkcase upper and lower section and it says 50nm. Is that the right one?
I forget the size of the bolt, but its either
M6: 6 + 1.5 ft-lbs
or
M8: 15 +1.5 ft-lbs
There is no specific value given in the book, so you use these values listed for 'all other screws and nuts'.
M6: 6 + 1.5 ft-lbs
or
M8: 15 +1.5 ft-lbs
