Toasted injectors - why?
#31
Originally Posted by MPD47
Anders, I had a similar problem when my wiring harness was junk. Cut back the boots on a few of the injector connectors and see if they are shorting out. I burned up one set of injectors and couldnt the car running correctly and that was found to be the culprit.
#32
Originally Posted by sweanders
Thank you for posting this, I have been toying with the idea that the injector harness is shot. Unfortunately the car will have to sit until I have time to fix it.
