stereo wiring
Left Front - White
Right Front - Black
Left Rear - Yellow
Right Rear - Red
and then between the two wires for each, the one with the black stripe is the negative wire.
Power wires:
ground - brown
constant power - green
ignition power - red?
And make sure you connect up the antenna amp wire, which is the small black wire that comes off the large antenna wire, otherwise the antenna won't get any reception.
Right Front - Black
Left Rear - Yellow
Right Rear - Red
Power wires:
ground - brown
Correction - the wires with the brown stripes are the ground wires. I'd been doing too much stereo wiring with the blaupunkt harness and forgot all the porsche grounds are brown.
And on mine both power wires are hooked up to the green one (constant and ignition). Don't know the actual way of hooking it up, but it works fine as it is. Doesn't turn on without the key or anything.
