MAF induction noise
Originally Posted by facboy
i will, but it won't. it literally is a pinhole...worn there by some previous twit leaving the water pipe hose clamp on top so that it has been rubbing on that pipe for years.
I doubt a pinhole is causing the problem. Keep on looking!
Originally Posted by Luke
My car sounded like an 'airplane' according to the neighborhood kids.
Chris, If the turbo is not primed properly, as per the instructions, it will not live long.
However, before you declare it damaged do some more testing. There will be some play, I emailed you some specs.
