replacing A/C lines???
On my new 951 all of the A/C lines leak and i want A/C so im going to replace everything but the condeser and evaporator because i dont think they leak. However, concerning those two big lines that run from the drier to the evaprator in the cabin and the evaporator to the compresser, to replace them, do i have to pull out the dash or is there any way to avoid that?
It's probably not your lines that are leaking. The little green seals at each of the joints is probably where you are losing your charge. Most are not that bad to get to, but the ones at the firewall are a major pita with the engine in the car. Take the car to a shop and have the old charge gas vacuumed out. Then systematically replace every seal at every joint in the system. re-charge the system and you should be able to hold a charge.
