Stock front swaybar size for 87 Turbo
Ok.. whats the stock front swaybar size for a 87 turbo? Clarks garage says 22.5mm but there isn't an option on paragon's site for a 22.5mm bushing.
http://www.paragon-products.com/prod...parts-late.htm
I need the center front sway bar bushings.
Edit, maybe i'm just stupid and need a 23mm bushing.
Originally Posted by WesM951
Jim,
Thanks, so your saying I need to order the 25.5mm bushing?
Are you absolutely positive your car has the original sway bar on it?
Just measure it to make sure - calipers, or try fitting open end metric wrenches, or tighten a crescent wrench down on the bar and measure the jaws, or check the part number (951 343 794 02 = 25.5mm) on the bushing if it is still legible.
And I'm corrected once again. Mine too has the 25.5mm bar and that's what I installed last week. Not sure what I was thinking.
Thanks Oddjob. Sorry for the confusion Wes.
