HEAD QUESTION
All 2.5 N/A and Turbo heads are the same dimensionally. Turbo and Turbo S heads are the same. The difference between turbo and N/A heads, valvetrain aside, is the Turbo heads have a cast in ceramic liner in the exhaust port to keep the exhaust gas as hot as possible in order to warm up the catalytic converter as fast as possible.
944CS is correct regarding the specs on the 944na vs 951 vs 951s - however, the primary purpose of the ceramic exhaust liners was to insulate the head from the higher temps achieved with the turbo and to retain more heat energy in the exhaust passage between the head and the turbo. The pic is from the 1991 service manual - Turbo supplement.
