Bad seal between the MAF and Turbo?
Ok, after a GREAT deal of time I am finally getting around to doing the Vitesse MAF install. I am removing the Autothority MAF that came on the car. The Autothority was part of a PowerHause kit that the previous owner put on. Here is the odd part. The bottom of the metal piping that went to the turbo had been reshaped for some reason. I am guessing to get a better fit? I don't know.
The point is, it was done VERY badly. Pics would help but everything is up at my buddies house. I am not sure who did it but when I pulled it out, it was obvious that there was not a good seal AND the hose clamp was not entirely around the whole mess.
So the question today is would a leak in this area have contributed to my running way rich and low horse power situatuion?
IPSC
IPSC
In front of the turbo you have a low pressure area (turbo is pulling air). I suspect you were running lean, as you will be sucking in unmetered air (air entering the turbo after the MAF).
Ya know when I bought this car part of why I was interrested was the Powerhause stuff already installed. Now here I am slowly replacing EVERY bit of it...
IPSC
