8mm and 10mm compression to -6 and (9/16 jic 37)
8mm and 10mm compression to AN -6 and (9/16 jic 37)
where on earth do you get these? (mean that literally)
I have everything else, just missing theese. I'm a few of them as some friends with audis/porsches has some problem.
Anders some info that might be of help (part #, prices and availability may have changed) (A friend "JH" found this out, so credit goes to him")
Part #, Description, Sources...
Line to Fuel Pressure Dampner
JM 0608TL 8mm hard line fitting to -6AN fitting www.europowerinc.com www.motionindustries.com $8.91
4051 Compression nut for 8mm hard line www.europowerinc.com www.motionindustries.com $0.81
10054 Bite ring for 8mm compression nut www.europowerinc.com www.motionindustries.com $0.57
FS-6 AN -6 Fitting www.batinc.net www.batinc.net $5.50
Line from Fuel Pressure Regulator
JM 0610-TL 10mm hard line fitting to -6AN fitting www.europowerinc.com www.motionindustries.com $9.22
4101 Compression nut for 10 mm hard line www.europowerinc.com www.motionindustries.com $0.90
10104 Bite ring for 10mm compression nut www.europowerinc.com www.motionindustries.com $0.69
FS-1606 16 x 1.5 Metric to -6 AN fitting for Fuel Pressure Dampner www.batinc.net www.batinc.net $18.30
4" Braided -6 AN Hose Jegs, Summit Racing $20
John, Let me get this straight........vendors are buying parts that are for the most part available locally and reselling them for almost double for a few minutes worth of work? How can this be allowed to happen without them being attacked, copied, or undercut?
Originally Posted by royalschwarz
Do we have direct links to the parts on Motion Industries website? I can't find them and EuroPower's website is useless.
The Jm-0610-TL fitting can be a pain to get from Europower sometimes as they "say" they have to get it made if it's not in stock. in that case you can use the JM-0810-TL fitting (what's used if you want to use a -8 line to the dampener) and get an -8 to -6 reducer from Jegs. I always order an extra bite ring to keep handy in case you ever have to pull it off.
fuel rail is is core from injector.com and it will have no damper, just a 90 degrees and a 180 degrees. reg is also AN allready, so when I get the last fittings It should be all good. but as for the rest running stock setups here, they will probably appreciate you mentioned the parts.
for all us euro guys look here.
http://www.isa-racing.de/20074/webse...-seite-013.htm
part number E104020 and E104022
Herr Unmöglich
Or other people who don't want to build fuel lines, but just want to buy them ready to go. I've definitely learned some jobs, while very much possible to DIY, are just better to let someone else do.
It may not be for you or me, but what about someone who bills $250 hours. Is it worth it for them to waste 3 hours building fuel lines? Nah.
At least Vitesse is up front about it!
Originally Posted by schwank
Service. Most car guys don't want to go to the freakin bolt store. I tried to go to Fastenal, they are not open outside of weekday biz hours. That sucks for those of us with day jobs. So people order it with their car parts. Not to mention the warranty. What happens when you screw up and burn up your car?
BTW, if you think some of the vendors who sell these lines will be responsible for your car if you catch fire you have another thing coming. I’ve put together about 20 of these kits and they take about 15 minutes to assemble.
Herr Unmöglich
I know, I'm just saying. Some of our vendors are stand up people and will go to great lengths to take care of customers. I wouldn't expect them to cover a car fire but from what I've seen Vitesse makes good stuff and stands behind it
And I needed me beer at the time... so I was being way too literal I guess. Meh.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Nice find. Thanks to you and JH, been looking for a good metric source.
Want an stainless 90 elbow adapter from HV pump to -8AN maybe these guys can do it.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
take care,
Jason
take care,
Jason
