Stock Sway Bars
Originally Posted by Thom
26,8 mm front / 18 mm rear.
The rear was switched from 18 mm to 16 mm during the '89 Model Year.
It will be "better".
As you may already know the 19 mm is adjustable so you can set it to how you like it best.
I would first make sure the rear shocks are in good condition and do not need replacing. Fitting a bigger sway bar with shocks in average condition is not the best thing to do IMHO.
I had the bar omn my 944s on the mediem setting. I did like the way that car felt.
