PSC1/MAF Wiring
PSC1/MAF Wiring
Okay guys.. Im stuck!
I'm down to the last wire to hook up with the MAF kit and I'm paranoid about getting it setup correctly. I have a PSC1 and SFR MAF, but I don't know where to hook up the BROWN wire from the MAF.
I spoke to Tim on the phone and he mentioned that it will need to go to the Signal Ground on the Air Flow Meter, or Sensor ground on DME. He mentioned Blue/Green as the color to look for, but according to my documentation this wire is labeled as "Air Flow Sensor -- 3". Is the blue/green wire (pin #9 on DME) the correct location for the Signal ground wire from the MAF?
Thanks for your help!
Nick
Nick
Here's a complete listing of my wires:
PSC1-004 (Wired using these instructions: http://www.splitsec.com/products/psc1/PSC1004.htm )
Violet
Red
Black
Grey
Yellow
Green
MAF:
Red (MAF Power Supply)
Black (MAF Ground Supply)
Green (MAF Signal Power)
Brown (MAF Signal Ground) <-- Where does this one go?
Violet
Red
Black
Grey
Yellow
Green
MAF:
