DME for 87 needed
Paul, I do not have a DME, however you can use the MY86, MY87 just the same.
Unless you are looking for a spare DME (to match the 24-pin one you have), you can get the later style DME (28-pin). If you purchased your chip from Vitesse, I will swap the DME for a 28-pin for you.
Hi John,
The mechanic opened up the dme and fixed it. I got lucky and stumbled on a really good mechanic. I told him to go ahead and install the stage II I just got from you so should be having fun by monday
Good deal. Make sure to print the turbo installation documents and pass them on to him.
BTW if you have the chip/board it can be used on 24 or 28-pin DMEs.
