Why is there no throttle cam for the turbo?
Old 03-24-2007, 10:43 PM
jmporsche944
jmporsche944's Avatar
Default Why is there no throttle cam for the turbo?
I used to have an n/a and put the throttle cam on and like it alot more. I feel like the pedal travel in the turbo is way to long. I would much rather a shorter more responsive pedal. Any ideas?
Jeff
Old 03-24-2007, 11:27 PM
Guns951
Guns951's Avatar
Probably because you'll need more than a direct throttle cam to increase throttle response - plus the throttle mechanism is highly improved over the NA. My opinion, not to be taken as fact, just a thought.
Old 03-24-2007, 11:31 PM
Douglas Sorrells
Douglas Sorrells's Avatar
Old 03-24-2007, 11:35 PM
Camaro_Muncher
Camaro_Muncher's Avatar
You DO have a throttle cam.
Old 03-24-2007, 11:47 PM
Guns951
Guns951's Avatar
On my comment I was speaking of a revised throttle cam vs the stock one. I believe his question was referring to why there isn't an improved version of the stock cam.
Old 03-25-2007, 02:28 AM
Techno Duck
Techno Duck's Avatar
Jeff
The 944 Turbo already has a circular throttle cam. There is nothing to improve on.
Old 03-25-2007, 04:05 AM
333pg333
333pg333's Avatar
I'm sure I've seen some device that opens up the throttle more rapidly due to a larger wheel. There's probably an element of turbo lag that increases the sensation that nothings happening when you first put your foot down compared to an n/a car.
Old 03-25-2007, 06:26 AM
billthe3
billthe3's Avatar
Doesn't paragon sell a throttle cam for the 951's? Or is that only for 944's?
Old 03-25-2007, 07:42 AM
Geneqco
Geneqco's Avatar
Yeah, I was thinking maybe that's the one Patrick has seen - it's only for the 944.
Old 03-25-2007, 11:18 AM
RKD in OKC
RKD in OKC's Avatar
Applying more throttle faster will not decrease the turbo lag one bit. And a more aggressive throttle pedal will make it more difficult to control after the turbo is spooled. You would be turning the throttle into more of an on-off switch.
Old 03-26-2007, 12:38 AM
jmporsche944
Yeah, i can see how that was confusing. I meant the throttle cam upgrade like the n/a has. It just like moving my right foot less and getting the same response I guess. Most newer cars that i have driven today seem to have far shorter throttles then the 951.
Old 03-26-2007, 02:42 AM
pjburges
pjburges's Avatar
If the turbo's is already round.... why not just make one with a different diameter? Or is this literally re-inventing the wheel...
Old 03-26-2007, 03:21 PM
jmporsche944
Yeah that makes sense to me. Id buy it. I think its going a little overboard to say that chaning the throttle cam would turn the car into an on/off switch. The throttle travel is pretty damn long compared to some modern cars.
Old 03-26-2007, 04:13 PM
JDeitz951
Lifetime Member
JDeitz951's Avatar
Maybe the sensation you are feeling is not lack of throttle action, but just the usual turbo lag on a stock engine. Is your engine stock? If so, putting on a manual boost controller (even just and LBE) will make the throttle more responsive. I rarely need to put the throttle past half way, unless I'm calling for warp speed. I have chips, MBC and 20 psi (K26/8).
Old 03-26-2007, 04:14 PM
Jfrahm
Jfrahm's Avatar
There is a lot to be said for some throttle travel when driving a turbo car on a curvy mountain road.
Quick Reply: Why is there no throttle cam for the turbo?
