Moving air intake....
Originally Posted by tconn
Thats the pic I remember!
Was there a follow up to the install, how well did the setup work etc ?
Ok, I'll do a search.
There are two reasons why I want to do this.
1. Cold air
2. The MAF never fit well. It rubs on the underside of the hood. My 89 has a diagonal brace under where the MAF sits.
The brace keeps the MAF from sitting low enough to clear
the hood.
I figured that if I relocated the air filter I could then move the MAF a couple of inches so that it would sit lower in the engine bay.
1. Cold air
the hood.
1. Cold air
the hood.
1. Cold air
the hood.
1. Cold air
the hood.
1. Cold air
the hood.
I am thinking of moving the air intake to the front fender.
I think I've seen where others have done this.
What required? Where do I ge the parts?
Those that have done this, have you had any problems with
this setup?
Thanks for any and all input!
this setup?
Then I could use the brake cooling duct to feed air to a cloesed filter setup..
I am using 968/993 style brake cooling ducts for the brakes
