New Product - 951MAX Booster
Sounds good Russell. A chip is probably all I will ever do to my 951 and the APE chips I have in there now make me a little nervous because i keep hearing that they run rich in midrange. I don't want that to wash my cylinder walls.
Thanks again.
Thanks again.
Originally Posted by rberry951
At some point I would like to do a dyno with it just to see what the performance gains are. And I do not quote 'estimated' performance gains on anything because I simply do not want to mislead anyone as every car is different and a car in a particular state of overall health will do better/worse than another. So unless I have a chart someone has given me with numbers on it, I don't spew numbers. This chip will cause the car to run a slightly higher than stock boost level in spots, which is why I have to modify the overboost protection a bit to account for this. I don't want to send people into limp home mode every time they floor it on a long track. The overall performance is what I shoot for, not the peak HP numbers anyway. People who have my chips ALWAYS tell me their car performs better all around than it ever has. Some aftermarket chips just try to achieve the highest peak HP, I don't. I achieve highest overall performance.
Regards,
Russell
Regards,
Russell
I really like the sound of this chip, except for the lowered redline. How much more would it cost (if at all) for you to increase redline back up to 7k? I would like it for autox purposes, and we all know sometimes that little bit of rpm helps.
Finally, another question: how would the performance be affected if a Lindsey Boost Enhancer was installed along with the chip?
Collin
Temprarily Banned per IB
Originally Posted by ausgeflippt951
So, uh, would you like a guinea pig? I'd be happy to get the chip from you for, say, free, and then take it to a dyno for testing???
Collin
Collin
I use guinea pigs for new chip development. They typically go to the dyno 2 or 3 times each testing the development chip against a stock chip, and they get a free chip out of it. This isn't a development chip so I am not in need of a dyno. The dyno charts on my website and forum are donated by customers who want to show their performance, I don't buy dyno runs. Sorry.
Using a boost controller to raise boost with this chip would be the same as raising boost with a stock chip, you would run into the overboost protection if lucky, pop a head gasket if un-lucky. This is a chip for a purely stock configuration, no modifications what so ever to boost. A test pipe won't hurt.
Regards,
Russell
Regards,
Russell
Regards,
Russell
While it technically raises boost at lower RPM, the max boost is still a constant, so it doesn't seem like there's any worry about overboost, correct?
So I was just wondering how the enhancer would affect the performance of your chip, given that the purpose of the chip was to raise performance everywhere in the rpm range. I really like the sound of your chip, and I really like the sound of the LBE...can't I have both???
thanks
Collin
I was actually referring to the Boost Enhancer: http://www.lindseyracing.com/Merchan...1BOOSTENHANCER
thanks
Collin
thanks
Collin
I'm kind of torn on this issue. From the theory side, the LBE shouldn't hurt a thing if set very low. But the boost level it 'begins' to open at can differ vastly from the maximum boost it will reach, or when it fully opens simply because it is a simple 'spring' device that can be effected by factors such as temperature in its function. I don't advise using it for that reason. Also in theory if it takes your boost too high the overboost protection should protect you, but I'm adjusting the overboost protection a bit because I know the power this chip makes is going to raise boost slightly, and the chip will be mapped for that higher boost, but I feel further 'enhancing' the boost could be dangerous. I'm going to stick to my original statement, 'not to be used with any other modification', with the exception of a test pipe.
So again, this chip is aimed at a stock vehicle, with the only change being this chip.
Regards,
Russell
Originally Posted by WesM951
Russell, I can post my dyno chart of the APE Stage II chips if you'd like. Super rich running 15psi.
Otherwise, sounds like a great product!
My only point in all that is this, I simply do not have a single mapping that encompasses the 951. I have over 70 variations of my 951MAX chip, and that number continues to grow as people throw more obscure combinations of modifications at me. The Booster chip will be a 'one fits all' chip, for a completely stock 951. Which is why I will charge less for it.
Regards,
Russell
UPDATE:
Local fellow Van Svenson took the Booster chip to the dyno today. The dyno fellow had him use the Romar method, run through the gears shifting low and running to 6500. He's going to send me the charts tomorrow but they only show 5100-6500RPM, not much use other than it shows peak HP/TQ of the stock chip vs. the Booster chip. Completely stock Turbo S, no boost controller, nothing to change but the DME chip. Raw numbers are:
Stock chip= max at about 5,100 - RPM 252 HP/258 ft-lbs
Max chip= max at about 5,100 - RPM 263 HP/270ft-lbs
I'll post the chart tomorrow, but again, it only shows peaks, no real useful info. Oh well...
Russell
Russell
Hi Russell,
Have these figures been converted to flywheel numbers or were Porsche ultra conservative in their HP and TQ claims - it seems the stock figs almost exactly coincide with teh claimed flywheel HP & TQ.
I have no idea, I don't even know where he took it or what kind of dyno was used. The two lines in my post are just copied/pasted from his email to me earlier today. Tomorrow I'll have the charts and they should say SAE or other correction if any. As I always tell everyone, different dynos produce different peak results, and different cars even though same configuration/age will dyno out differently as well. I'd like to get a real 2000-6500 run to see the HP/TQ/AFR/BOOST across the board, but this particular shop just didn't do it that way. I'm pleased that just the chip change made 11HP and 12TQ, but peak numbers just don't do it for me. On the last dyno Jessie posted for the 944S chips the peak gain was just a couple of HP, but across the power curve there was as much as 15HP more in places. My goal is always to deliver the most overall power, not peak which is just a spike on the graph. But, that is all some people care about is braggin rights on peak numbers. We call them Dyno-Queens.
I'll post the charts when I get them tomorrow.
Regards,
Russell
Regards,
Russell
UPDATE:
Russell
Russell
Originally Posted by Luis de Prat
Is the fuel pressure regulator stock as well? It was my understanding that a higher rated FPR was needed when chip'ing a 951.
Yes, FPR is stock as well. Most aftermarket chips require a larger FPR to facilitate higher boost levels. Since these chips are designed for a car with factory boost, factory FPR is sufficient. I believe this is the only chip like this on the market, it truly gives you more power without changing anything but the DME chip. It keeps factory overboost protection and as you can see from the dyno chart I kept the AFR almost identical to stock. Everyone is used to adding several mods with their chip to gain power, always thinking that you can ONLY gain power on the turbo car by increasing boost. This chip is for the person who either cannot, or does not want to modify anything on the car but the DME chip. Again, this chip is designed for a bone stock 951.
Retail price on this chip is 199.00 USD, Rennlist promotion running through 4/21 is 149.00 USD.
Regards,
Russell
So, let me see if I understand correctly. I can stay with my '91 stock set up, and cycling valve and change nothing but the chips? Almost sounds too good to be true. Will the CV still protect the engine well enough from overboost? Thanks for the quick response.
Regards,
Russell
