Good way to test AFM
Hello everyone,
I am having an issue with a stumbling issue around 2700-3700 rpm. Someone suggested it may be the afm. Is there a good way to test it? I have it out while in the process of replacing the vacuum lines and various clamps.
Mods are as follows:
2.5" testpipe
Max Chips
3 bar fpr.
Running stock boost as MBC is not installed yet.
Also as an addendum to the clarks-garage writeup on fuel rail removal.
Step 7= pull harder than **** and watch gas spray everywhere
two of the injectors stayed put and the other two came off with the rail. I am wondering if the retainer clips may have suffered and just replace w/ upgraded units.
Patrick
2.5" testpipe
Max Chips
3 bar fpr.
Patrick
