Cylinder compression test
Originally Posted by Bonestock951S
How did you get it out?...
-Darwin
-Darwin
Originally Posted by Fluidplay
Dan, I'm also curious about this taper? do you mean that there would be different measurments for compression from top to bottom in the cylinder? how can you test for this? thanks for all the info!! Dennis
good idea mtnman... i'll hook up the tester directly to the compressor, just to see if it is showing the same psi. By the way i'm at sea level too. South O.C. CA. Does anyone have any data on compression tests at various altitudes?
Side bar thought... trying to remove the crank pully on a different 951 engine with a 735 lb impact wrench and it's not budging. ideas anyone? appreciate all the help!!
The preasure decreases with altitude, amazing anyone could live/breath at the alitudes of Everest, 4PSI
http://www.sablesys.com/baro-altitude.html
