blown head gasket...now what
Exactly. Do I go for the quick fix ($200) or go-for-broke with a nasty rebuild ($4k = 400hp)? It's a tough decision, really. Hmmmmmmm.............
Originally Posted by 87944turbo
How long do you plan to keep it?
I just need to determine how much more life I can get out of the bottom of the motor before it absolutely must be rebuilt. I don't really want to spend a ton of extra $$ right now...but I want even less to take it all apart again in 5k miles after I put it all back together.
Originally Posted by special tool
How did you diagnose a blown headgasket?
Originally Posted by turboted
I noticed a small puddle of coolant under the intake manifold and and suspected the culprit was a leaky heater core hose on the back side of the motor. But when I removed the intake manifold to get a closer look...it became clear that the head gasket is on it's way out. It's just starting to seep...nothing major yet. I've had no other symptoms, so I suspect I'm catching the problem early.
hmmmm- not so fast.....
There are many things thatr will leave fluid there.
The most likely is the cam gasket, then injector (top or bottom) then intake gasket.
What does the inside of your oil cap look like when you open it?
the coolant vent screw at the front of the motor could also be leaking coolant, which would run along the outside of the gasket.
a sure way to test if the gasket is actually blown is to perform a compression/leakdown test. very easy to do yourself.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
It's been a lengthy project...as I've also replaced the oil pan gasket, steering rack, rod bearings, clutch master/slave cylinders, oil cooler seals, and front/rear suspension (Koni adjustable coilovers - nice!). With a newborn at home, I've only been able to work on it for a few hours a day since January. I'm happy to see the light at the end of the tunnel...finally. I'll post some new pics once it's all done.
I don't think that you have a blown head gasket. If you do, it is an easy swap. Unless it has been sorely mistreated your motor should not be anywhere near ready for a full rebuild, I have seen them with close to 300k miles that still run perfectly....with the original HEAD gasket and turbo. These are some really tough engines if treated right. You can not let the oil level get low or old and you have to be diligent about the belts.
At 87k I wouldn't worry about the rod bearings either unless it has been tracked or the oil not maintained properly.
As someone stated in an earlier post, there are alot of ways you can get oil there, the head gasket probably being the least likely culprit. You can pressure test the cooling system and see where it is leaking.
16psi is nothing on these cars.
