Best chip set-up for 18-23psi boost???
#91
Also Bill (22psi) and specialtool (28+psi) any insight???
#92
i found that with the vitesse stage 3 i have i would start to get pinging at 1.8 bar, which is 26psi. that was on pump fuel. but for everyday i ran the car at 22psi.
#93
Originally Posted by hosrom_951
Using danno's old 18psi chips, i was suprised how just chips made the stock car faster. It was stupidly fast over stock, i was laughing how a simple upgrade made the car go. However, i am running 16x7 front and 16 x 8 rear Fuchs, and the rear wheels were spining in WOT 1st and a tad on 2nd, NOT dropping the clutch, and running 225/50 in the rear.
Since i am keeping the fuchs, the max i can go for is 245/40 in the rear, hence anything over 330whp would probably just make my tires spin in all three gears, and the weather here is dry, you cannot get as dry as here as anywhere else
I believe tires make a difference, what where you running?
#94
yeah i know. i just keep turning it up. i knew the engine was coming out so for some mods so i wanted to give it some boost for a while. i did a HG on my car 3 months ago and when i pulled the head off last week i noticed that number 4 cyl down the bottom was soon to fail. the engine will be a 2.7
