Best chip set-up for 18-23psi boost???
Old 02-01-2007, 08:49 PM
  #31
clouddomino
clouddomino's Avatar
So say with a racing ported head (maybe a Lindsey set-up) would that enable more boost?
Old 02-01-2007, 08:54 PM
  #32
2bridges
2bridges's Avatar
I give up..... you are totally missing the point here. Fuel octane will sustain a certain amount of compression before it will combust (without ignition).
Due to variations in fuel - running the ragged edge of detonation is rediculous for the street on pump gas. Some people do it.... I just call those people idiots
Edit:
sounded a bit harsher than intended.
  #33
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Originally Posted by ehall
I wrote that unclearly. It should have read that detonation isn't going to change based strictly on the turbo. My point was that there are many factors that go into detonation, and just changing the turbo is a long way from eliminating all of the additional factors.
agreed.
Rogue
Old 02-01-2007, 08:57 PM
  #34
clouddomino
So instead of blaming the inability of 21+psi on head design, then the fault is the fuel. So to remedy this wouldn't be safe to say that with proper octane and timing advance that 21+ is definately possible. So the fact is not that it isn't possible, it just isn't good for the engine to run 21+ on pump gas.
Old 02-01-2007, 09:02 PM
  #35
clouddomino
I'm not claiming any mastery of these cars or they're set-ups. I'm used to working on small block chevy's for dragging. So it's a learning experience for me, I'm just trying to relate some of my mechanical know-how from that to these cars. And from experience I've learned that with the proper time and research anything is possible, it's mainly what your financial situation is... Is that not true with 951's as well?
Old 02-01-2007, 09:03 PM
  #36
Rogue_Ant
Rogue_Ant's Avatar
Originally Posted by 2bridges
I believe somebody is misleading you. 25psi on pump gas is absurd. Maybe a one time shot... and it was probably 20 and grew to 25 the more they told the story. Is BS
Not BS. I help my friend tune his Eclipse. He was tuned for ~25.5-26psi on pump gas. However we had to pull a lot of ignition timing to not knock (peak of 8.4 degrees total advance). We just retuned it to ~23.5psi and managed to get 17.2 degrees advance without knock. Completely stock longblock with ARP headstuds. Larger turbo (Holset H1C), 3" exhaust, Front-Mount IC, upgraded fuel-pump, injectors and AFPR.
The biggest thing holding our cars back is the inability to monitor knock effectively. Without knock monitoring you are simply guessing, period.
Rogue
Old 02-01-2007, 09:07 PM
  #37
clouddomino
Thanks Rogue excellent example of import tuner's pulling 25+ psi on pump gas. I'm just trying to figure out a way to do this with a 951. Surely there's something that can be done to advance and tune our cars so they can run boost safely without detonation... right???
Old 02-01-2007, 09:11 PM
  #38
lart951
Basic Sponsor
lart951's Avatar
I have ran 19psi on pump 91 gas for almost a year no problems reported. *
*so far
Old 02-01-2007, 09:13 PM
  #39
clouddomino
lart951 what type of set-up are you running? Chips, injectors, headwork????
Old 02-01-2007, 09:16 PM
  #40
lart951
Basic Sponsor
lart951's Avatar
55lbs injectors, authority chips, lindsey power perfect MAF, lindsey super 61 turbo . tial 38mm.
Old 02-01-2007, 09:17 PM
  #41
clouddomino
You took the autothority chips to dyno tune or a running a specific stage?
Old 02-01-2007, 09:24 PM
  #42
Bri Bro
Bri Bro's Avatar
Laust Pederson says he's pushin' 25 psi... Any insights Laust???
He just told me he was at the track running 25lbs on 91 octane...but with water injection. Try this without injection and you will not run for long.
Old 02-01-2007, 09:25 PM
  #43
ninefiveone
ninefiveone's Avatar
I think you should consider the differences between a Lancer EVO and a 951 motor. From your experience with small blocks I'm sure you know something about how engines work, how to tune the, and how changing different thing change power, etc.
Old 02-01-2007, 09:26 PM
  #44
Rogue_Ant
Rogue_Ant's Avatar
The main issue is, like I said, the inability to monitor knock. Our lack of logging ability is really the problem. That is why I've been working on being able to log knock (Knock Thread). But we, the community, don't know what a safe threshold is. I do believe some might know, however they tend to stay quiet.
Besides software issues, the common Japanese head is better at warding off detonation then our 8v heads... however I believe that advantage is null compared to our 16v variants. Just not many boosted 16v guys really pushing their motors.
BTW if you want to look at the logs from my friend car, you will need the DSMLink client:
DSMLink
And here two different pulls/tunes (all third gear):
~25psi
~23psi
Rogue
Old 02-01-2007, 09:27 PM
  #45
lart951
Basic Sponsor
lart951's Avatar
I tune my a/f ratio with the power perfect.
Quick Reply: Best chip set-up for 18-23psi boost???
