Morning Question: Ground Wire.
There is two brown ground wires that come out of the wire harness at the top of the bellhousing. One fits on a stud that takes a 13mm nut. Where does the other go? It has to fit soemwhere in that area but I can't find a stud or anything to tie it to.
TIA
TIA
The other wire should fit on a stud that takes a 10mm nut. I believe there is a clamp there that holds the starter wiring...or, you could bolt it to the bracket on the intake manifold that holds the speed and reference sensor connections.
Originally Posted by PorscheMD
There is a hole right next to the 8mm stud. It is somewhat hidden towards the intake runner. It takes a 6mm bolt. There is not a stud there. The hole is less than an inch from where the ground wire fits on the stud.
