SS Brake Line ?
SS Brake Line ?
Well i was painting my calipers (which look awesome IMO):
But I stripped out the bolts that tie in the hydrolic hardline to the calipers on both rears and my friend broke off the front bolt on the drivers front. So where can i get SS braided lines for the rear and for the left front?
The OEM hard lines are like $70 freaking bucks each so i want a "universal" type Line that i can use for both sides in rear and for the front. Need to be about 1 1/2' and have the right bolt size to fit the 88' (non-s) calipers.
TIA
-Jace
TIA
-Jace
here is a couple of sources for them:
http://www.944online.com/cgi-bin/ASI...ystem-944turbo
and
http://www.lindseyracing.com/Merchan...e=944BRAKELINE
and
Paragon Products also has them, and a little cheaper if I recall ~ $65 for the set.
Interesting front strut assembly - do you know what spring that is and where the lower perch came from?
Oddjob: umm no and no, haha. Everytime I have the wheels off, i always forget to look at the spring rate markings. Ill take a look in a couple days when i have to take them off agian to put the lines in.
Thanks for the help guys!
